F&B 6BBL 572Hemi (Taking the Bird apart)
Re: F&B 6BBL TPI XFI 2.0 on 572Hemi with StageV heads and Mo
george68hemirr said:
.......572 HEMI 6BBL.....
I think you dropped a couple of barrels there, Skippy... :basketcase:
he's just trying to keep with the sleeper look.... :basketcase:
dutchrunner
The Netherlands
:party: :thumbsup: :banana:
Wiring is done.
Left to do :
Check fuel system is closed/not leaking.
Check after engine priming if MSD/ECU will give spark and correct timing .
Check fans are running/switched on by ECU.
Date has been set(90%) on Manday 29th April for pick-up of car and fuelmapping start.
Steve
Chesterfield,England
Wiring is done.
Left to do :
Cool,remember to post a video :thumbsup:
dutchrunner
The Netherlands
And date has been moved to 6th May.
Shop was closed week of 29th April.
Yes Steve . Will post movie. Also we are already making plans to come to Santa Pod 2014.
Steve
Be good to see you and the car Dutch :thumbsup:
dutchrunner
The Netherlands
Re: F&B 6BBL TPI XFI 2.0 on 572Hemi (Update Fuel system pri
Put some birdseed in the tank yesterday.
After turning on pump(s) the fuel poored out of the sides of fuel filter.
Have removed cannister today and ? !!!
Where normally 1 O-ring is where now 2 C-rings.
Bruce from F&B Performance has put 2 new rings on priority mail.
Will test system after new O-ring.
C-rings :basketcase: Im patiently waiting :popcorn: :cartman: :nachos:
you don't need no stinkin filter, by pass that sucker and fire that Hemi up!
dutchrunner
The Netherlands
Not sure if the injectors like the unfiltered bridseed Basketcase.
There here in 5-7day.
you gotta be chompin at the bit! :popcorn:
dutchrunner
The Netherlands
Re: F&B 6BBL XFI2.0 572Hemi(Engine primed/ECU power/fuelclos
Work allmost done ,
Fuel system is closed even untill 70psi.
But when dual Walbros pumps are switched off the pressurer drops to 20psi.
Should stay atleast 30 minutes at this pressure. :eek: :huh:
ECU has got powerrrr and MSD send signal.
Primed the Elephant today and I now need the courage to turn the key on with fuel pressure on the fuelrail.
H*ly shit , that needs some guts/nuts.
do it.....dont be a pussy......hit that key :lmao:
:yeathat: :lol:
what could go wrong? :eek:
dutchrunner
The Netherlands
Tried to crank the hemi and I have spark.
But could not get in the ECU to pre-set some vrey important things.
So could not start it.
Will have to locate problem. Think my laptop and ECU speak wrong language.
csuk9
Camarillo, California
The ECU probably is speaking Japanese ! Damn those imports!!!!!!!
Sorry for the brevity... Sent from my iPhone using Tapatalk
dutchrunner
The Netherlands
Nope . The ECU is speaking USA and laptop Dutch. :lmao:
If you put an interpreter in line with it cause a slow throttle response :jester:
