Engine Block Castings Numbers DECODE
RR383
Tennessee
Fellows I'm having a bit of trouble de-coding the casting numbers on my block.
Casting Number: 2468130 3
4-7-71
What do I have under the hood?:huh:
ArmyInspector
if you want to know more about your engine, you would have to look at the vin in conjunction with the other stampings on the block.
the little pad on the front of the engine should have some stampings that will give you a little more info
