Electronic Ign.
abodybill said:
If I go with the pertronix II does it make any difference if I use a dizzy from an automatic single point or 4 speed with dual points?
Reason I ask is I can't find my oringinal dizzy 4 speed but buddy gave me 4 single point dizzys and I don't need to buy another one.
My dizzy was a single point, so IIRC when I did mine the Pertronix unit uses the same screw holes as the points and condenser did originally. So I don't know if they will mount to a duel point dizzy.
I got my Pertronix II today.
In the directions it has two ways of installing it:
With the ballast and Without ballast so which way is the best??
I don't know if it's the best way to do it, but I installed mine with the ballast, and have had no problems so far.
How much voltage do they say to feed it? The one without a ballast may be using resistance wire for voltage drop. I'm afraid its time to break guy code and read the instructions or call tech :lol:
Bill, The unit needs full 12v. The ballast stays in tact, and in the sytem as designed. They suggest splicing into the blue IGN/feed wire going to the ballast.
All the voltage it can handle Remember this is a GREEN car :acme:
I did break the guy code and read the instructions hence my posting :lol: :lol: :lol:
Craig,
I kinda thought that's what I should do but wanted to check as this system is new to me as I have always had the Mopar ecu system.
That was the #2 way of hooking it up in the instructions. :thumbsup:
:yesnod: :thumbsup:
abodybill said:
Craig,
Not sure which instruction sheet you have, but this one is about a year old. The end (or #3) schematic applies to us. It's a bit unclear, as they depict two wires going into the feed side of the ballast. I made a revised version that more clearly shows the hot Pertronix wire "borrowing" system voltage from the source side of the ballast in the form of a splice. I've included pics of the original schematic and my revision of #3 below (the "corrected" one is on top).... Hope this helps!
EDIT: I just realized that you have the Pertronix II unit. The schematic shown below is for their basic unit. Not sure if there is a difference? Post a scan or pic of your instruction schematic if it's different, I'd like to see it.
Green cars are electric :acme:
Mine is , I plug it in every night :jester: :jester: :jester:
A31PKG said:
abodybill said:
Craig,
Craig,
Will post a scan of the directions as soon as I can figure it out and how to do it.
Here's pictures of the directions I got with the Pertronix II and only difference I see from Craigs post is the very first one in Craigs is the points setup.
Other then that alittle differebt where to splice the Red wire in.[attachment=2:2zeqgazj]PICT0001.JPG[/attachment:2zeqgazj][attachment=1:2zeqgazj]PICT0002.JPG[/attachment:2zeqgazj][attachment=0:2zeqgazj]PICT0003.JPG[/attachment:2zeqgazj]
If someone sees something I'm missing let me know.
