stevo
Ok I know this has been covered but I am new to my 69 Road Runner, I am just putting the wraps on a 13 year restoration (its a long story) and I have an electrical bug.
OK....When I have the lights switch in the park and lights position my right hand turn signal light stays on.
When I use the turn signals it blinks just fine but stays on after I have moved the turn signal lever to neutral.
The left hand turn signal blinks just fine too, but this one only blinks when i use the turn signals.
If i have the lights switch in the off position and the key is in the right spot both signals work fine....
Here is my question....should the left hand turn signal light be on as well as the right one when I have the switch in the park position?
or how can I get the right hand signal dash light to juts work when i am using the signal?
I have gone over the grounds, I might have missed one and the signal switch in the column is new.
any help/suggestions would be very much appreciated.
