1BADBIRD said:Does this sound like too much cam for the street? 249*@50 557 lift
298* advertised. :cheers:
Sounds like a nice combo1BADBIRD said:Comp is 11:1 heads are milled,ported 906s Rockers are 1.6 rollers from crane. This is the engine I am building for my six bbl setup. MSD ignition, I used a factory steel crank, eagle H-beam rods, ross pistons with 60. overbore 440. let me know what you think. :cheers:
Also figured I would add its a 4 speed car with 4:10 gears and headers.
.thats what you have to watch is piston to valve clearances...which you can check with clay on top of your pistons...if it dont work you can also play with differant head gaskets since your compression is a 1/2 point high for 93 octane....10.5 is the max for cast iron block and heads...if you had a cast iron block and aluminum heads you could go 11 on compression....mine is aluminum block and heads...11.5 to1 comp for 93 octane.....1BADBIRD said:Comp is 11:1 heads are milled,ported 906s Rockers are 1.6 rollers from crane. This is the engine I am building for my six bbl setup. MSD ignition, I used a factory steel crank, eagle H-beam rods, ross pistons with 60. overbore 440. let me know what you think. :cheers:
mjoyner408 said:why can you run higher compretion ratio with alum heads vs. cast iron? 10.5 is ok for 93 with iron heads? i thought 10 and above = detonation[/i did some research years ago when i was building my 572 hemi to get the max compression for 93 octane pump gas and thats what i found out....looking through different websites...
