cj69RR
Anyone recognize this brake master cylinder setup? Having some issues from it and need to replace or repair it. Years ago Dad had someone convert from Drums to disc in the front. Both lines from the master to the proportioning valve are the same size. Front rotors measurements are about 10 1/2 inch diameter from what I measured with the sliding brake calipers. Thanks in advance.
