Rogue Runner
Wanted; coyote duster air intake, mines 53 years old and brittle. Need show quality if possible…? After market? OEM?
the heat is the problem if the ecu is in the unit bolted to the intake will over heat the ecu . if you use a 1/4 wood/fiber spacer it will help with heat soke.Hope not, we dynode the motor and got everything pretty dialed. We also have a guy that helps locals' with these quite often if we run into a snag.. He has all the right equipment for these units.
If you are talking about hood clearance for the FiTech with an air grabber, it will not be an issue. But the single plane hi rise intake is another can of worms altogether. No way that will work with a factory air grabber.that fiteck is or might be a problem.
Maybe looking at refurbishing mine is a better idea, it's not bad, just very brittle and rubber needs to be replaced with new decal.good luck hard to find. there is someone that refurbish your old one some body will chime in and help. you could check the other forum for b-body's only.
Great story... very nice RRI run a Holley Sniper on my 440 Valiant down in the desert in high heat with no issues same design more or less as the Fitech. I have read about some issues with the Fitech so I went Holley. Come to think about it I am useing an aluminum manifold but still 225 degrees at times.
ThanksGreat story... very nice RR
