Hoosier Bird
For those of you that may have never seen what holds the clutch fork in. Here you go.......
Hoosier Bird said:And yet another BFH, Torch and Channel Lock problem........ :brickwall: Head of bolts stripped so there is no way to get them out with a wrench.........So, I drilled the head off, pulled the bracket off and then the screws came right out..........
ACME A12 said:[quote="Hoosier Bird":137bo4gx]And yet another BFH, Torch and Channel Lock problem........ :brickwall: Head of bolts stripped so there is no way to get them out with a wrench.........So, I drilled the head off, pulled the bracket off and then the screws came right out..........
I've got to get a blanchard grinder..... :brickwall:69hemibeep said:Gary that does look good, are you saying you didn't have everything to chuck it up in the lathe :toetap:
Hoosier Bird said:Ok, i have 1 more tool to add to the list..........can anyone tell me what that would be....... :brickwall:[/quot
brother you did some magic on that wheel
