Fred69Runner
- Joined
- Apr 11, 2020
- Messages
- 74
- Reaction score
- 71
So it looks like every one else missed saying the 489 has a bigger pinion shaft than the 741 so you need a new yoke on the differential. They make like drop top say's a staggered U joint so you can match to your drive shaft. If needed you can go to a drive shaft shop and have that end changed so you can use the same size bearing through out. That is a better idea but the front bearing will still be small. At some point or another once I do put the 489 in my car will change from transmission to differential all the bearing's to the same size. Doctor Diff. Has a lot of the part's. Good luck my friend. Russ.
Hi guys, so I've been talking with some of the old school racers around here and being told that unless I'm going to be putting racing slicks on my bird and doing some serious street or strip time on her, that the 741 (with the smaller pinion and u-joint) is more than strong enough to put in a after market sure grip with around 3.55 gears and match up to a mild build 383 through a 4 speed. Any thoughts out there on going that route instead of trying to find and rebuild a 489?
Thanks
