Rear Main Bearing Cap Removal
Dennis Putnam
Loganville, GA
To remove the rear main bearing cap it appears there is a plate that needs to be removed first. However, the two bolts that need to be removed to hold it in do not appear to be normal (see attached). I cannot find socket that fits properly. It seems to be somewhere between 3/8 (too small) and 13/32 (slightly sloppy and turns on the bolt). How do I remove those bolts?
Nothing special. That is the rear main seal retainer and a 12 point socket 3/8" I think, maybe 7/16" in a 3/8 drive fits mine. 1/2" drive socket is to fat
Dennis Putnam
Loganville, GA
Thanks. Finding a 12 point locally may not be a trivial task. I'd hate to have to wait for mail order.
P.S. The color of yours appears to be the same a mine (blue fire metallic). :)
Am also concerned about amount of grit on bearing journal. Please clean it off and post another pic. Curious to see if it is scored at all.
Dennis Putnam
Loganville, GA
After visiting a few auto parts stores I finally found a 12 point SAE set and that did indeed work. Everyone had 12 point metric but few had SAE. Now I can pull the crank and get the block to a machine shop. Thanks for the help.
gefoyi5177
New Member
chicago
10 Effective Ways Remove Rusted Bolt With No Head​
Learn the most effective ways to remove seized bolts with no head while saving both money and time calling a mechanic.
It can help you.
