Any Ideas on where to get that foam strip that is really thin. It was placed between the window channel and the trim to seal the trim from water getting in.
Well thanks have not gotten that far yet. I am still on my dash trying to get it painted and installed. Then putting fender's and door's on the car to get the hood on to see if every thing is line's up before painting the hood. Don't know what I will run into hope nothing other than the striker bolt is a little off. Look's like I will have to drill another hole for it and tap it. The latch bolts up good. Man working on this part did not know I would have any problem's. Just keep moving forward is all any one can do.![]()
be sure to install your dash pad before you install the dash its almost impossible to install after the dash is in place.![]()
View attachment 29931 View attachment 29932 Found another petty blue road runner runner today here in Columbia S.C.
Yes that is why I am trying to get the darn thing painted. They sure did not give us any room did they.Yes 68 man that is why I order it form TCP Global paint. It is dull and guess it has a rough finish. Will see when painting it on.
