Pump gas?
Oh MsBeep I am getting paid so I'm not all that nice, just as around here LOL
mcmopar
Orlando, FL
I'd suggest putting some hardened valve seats in those heads or else you will have some serious valve recession sooner than later. Using a thick Fel-Pro gasket should help lower the compression enough to run on 89 -93 gas ok. You can play with the timing a little bit, too. Sounds like a fun project!
John it is getting hard seats
