Engine is ready Just need my Car back from Body Shop!
joewhite440
Industry, Pa
Thank you!
I have to get the Studs and gaskets for the Valve Covers. You guys have a tip or preference on where or best quality?
Thanks
Thank you!
Thanks
I used a mopar rebuild gasket set but I don't know if they still make them. No leaks
maybe I'll finally get my first ride in a Hemi car.
cj69RR
Fleming Island, Fl.
Looking good! Find that hemi a home. I have a place it could go if you need someone to store it while your waiting o. The body shop.
joewhite440
Industry, Pa
Looks good Joe, what's in it?
Not the best stuff but I have ran their stuff before!
Eagle Crank and Eagle H Beam Rods
JE Pistons
Stock Cast Heads
Mopar Factory replacement Solid cam!
Mellings HV Pump and Deep Pan and Windage Tray!
JE Pistons
Stock Cast Heads
Joe I take it your at standard stroke how about compression. And make sure you run a good oil with those solids, I have the same cam and no issues, works to 7000rpm and wants to keep going but I don't
