Torsion Bars
4spd69RR
Winter Springs, FL.
I have been thinking about raising the front of the runner using the torsion bars. Reasoning is, I have an eight quart oil pan that hangs down below the "K" frame. By turning the adjusters to lift, will I gain any more clearance for the oil pan or will it remain in the same location? Attach photo so you can see the clearance.
The whole front end comes up engine and all, you can look in the shop manual as to how high you can go and still align the front end
4spd69RR
Winter Springs, FL.
Yep, I have done this before on my old runner. The only thing I was doubting was if I would raise it enough so the oil pan does hit speed bumps. As it sits I have about 3.5 inches of clearance. I definitely want to raise the front a little, I like the level look.
just put some 22s on it, you'll have all kinds of clearence.......:basketcase:
you know that's not a bad looking car....for a white car. good thing it's a 4 speed post car :jester:
4spd69RR
Winter Springs, FL.
LMAO, 22's, mmmm, NOT gonna happen. I like a lot of rubber on my tires!
Another option is a skid plate on the K-Frame like a Hemi car has.
4spd69RR
Winter Springs, FL.
Wow, that's up in the nose bleed section, I'll need a ladder. Just want to take it up a couple of inches. May get a skid plate.
mcmopar
Orlando, FL
QUOTE=zupanj;121174]Then you could get your car on overhaulin' where they ruin and ugly up a muscle car a week. A Chip Foose tribute.[/QUOTE]
Pardon me, I need to...:puke::puke::puke:
I'd paint my car B5 before I'd let Foose touch it.....:acme::acme::acme::acme::acme::acme::acme::acme::acme::acme::acme::acme::acme::acme::acme::jester::jester::jester:
moparchris
costa mesa ca
On my 70 Dart street car I had a deep Moroso pan. I hit it a few times, what a mess. I built a skid plate and welded it to the k frame like John said. I still hit the skid plate on driveways, speed bumps aren't a problem as long as you hit them straight and slow. So I raised the car a 1/2 inch and it made all the difference. I cranked the tension on the torsion bar. This does 2 things. First it simply raises the car making more clearance. Secondly, it raises the spring rate of the torsion bar because it is under more tension. Both together will greatly affect your ability to spill your motors guts out on the road.
4spd69RR
Winter Springs, FL.
Well I have just raise her up, I now have a full 6" of clearance for the oil pan. Will add pictures later.
Kent
First, that's a great looking car. Second, I'm puzzled by the 8 quart oil pan. Your car does not appear to be a drag racer? Those model Mopars were designed to be killer street machine with occasional appearance at the track. With that said, if you have a B or RB engine toss that 8 quart and get a stock Hemi pan, It has a capacity of 6 quart and you solve your pan clearance problem.
You're replying to a thread that is three and a half years old. OP hasn't been on here for two or more...:facepalm:
