Ok now that I have everything back together from my engine compartment re-do im having trouble getting the car to run right.... Im about running out of options to check and starting to get frustrated....
Current issue is there is a major stumble/bog/hesistation when I stomp on it, in some cases almost wants to stall, after that stumble it picks up like id expect it to and runs good. With no load the car runs great.
set-up:
"Stock" 383 with; stock heads, Cast Manifolds, Edlebrock DP4B intake, New Edlebrock 1406 Performer Carb (600cfm) (did similar with the older carb that I just replaced), MP electronic Ignition w/Orange Box, New plugs, new wires, new fuel filter.....
Timing is set at 38 Deg total (per MP Ingition instructions), ~11 Degrees advanced at idle. Im running the vaccum line to the lower vac port on the carb (full time vaccum). I have tried to adjust the accelerator pump on the car both ways, to either add or remove additional fuel on initial acceleration but that hasnt helped, since im not really sure if its getting too much fuel or not enough under this condition. Im doubting I have any lines that are collapsing, since its almost instant its not so much doing it once the bowls are empty.
I have tried moving the vaccum line to the other port on the carb with no help. Im starting to think that this could be more of a timing thing now as I belive I have chased down all the fuel avenues, but to be honest im not real up on timing set up. So im looking for some advice on what to try for timing, or for any other suggestions. Thanks
set-up:
