trans x-member question
generaljmwlee
NEPA
is there a different rubber mount for auto and 4spd. I have a 4speed x-member and the mount is in front of the crossmember
I think you have the wrong tail shaft. The housing from the trans to the end is about 16.5" and the mount center is about 7.5" from the trans, at least it is on my 18 spline :popcorn:
generaljmwlee
NEPA
my tailshaft is 16.5 inches and about 4.75 to the center of the mount. I had it mocked up with the auto crossmember not the 4spd one maybe I will just use the auto one, untill I can get the right tail shaft
Is your shifter going to fall in the right place? Just wondering if this is an A-body or some other housing ?
generaljmwlee
NEPA
shifter is right where it should be was told the trans was for b or e body ,casting on the trans was PP 833 1070 so from what I checked its a 833trans build on 10/1970 correct? it has 2 shifter mounting plates
I had an A-body trans wasn't even close to fitting thats why I got this one
I had this very same problem. Many years ago, so my memory is kinda crappy (just ask my wife). I believe the 71 and newer b-body trans is different in the trans mount. I had a 68 that I had to make a new mount on the crossmember to put a 71 up trans in it. Bottom line is you will need to fab a new mount. I know someone here has more info for you, Ray?
What ever you do don't mess up that mount, they are hard to get. :popcorn:
generaljmwlee
NEPA
I had it mocked up an auto crossmember works just wanted to make it correct as poss with the 4spd mount , time to get the auto crossmember out of storage :brickwall:
