newbaufish
I purchased a 69 RR and one little thing that does not work as expected is the tachometer. It shows more RPM than the car is turning regardless of speed, at idle it is around 1500 to 2000 RPM when I keep it barely running and at 60 MPH it shows 5000.
Has anyone run into this. Is there anything else to check before sending unit for a rebuild? If a rebuild, does anyone have positive results with a particular company?
Thanks all.
Thanks all.
