Rust Prevention Magic
hotcob
Can anyone tell me if they've used this stuff on any parts and if so is it any good? Better than paint? Their blurb is that you don't need to paint the part so it looks natural metal but is still protected. Seems great if it works. Its called "RUST PREVENTION MAGIC" and its got RPM on the tin. Any info would be welcome.
Thanks
Re: Ruat Prevention Magic
There was some discussion over on moparts.com about it and some of the guys over there have used it. You might try a search over there
bigmanjbmopar
I have never used it sounds good. I have used rust bullet and I must say for the price and the little amount you get I was skeptical but 12oz covered dam near all of my trunk. My trunk wasn't bad overall but since the rear window was leaking into the trunk and the numb nut before me put house door weather stripping on it water got in and rusted the surface. Cleaned it up got rid of the looses stuff and put on the rust bullet here is a pick. there were only a couple of mall holes through which I epoxied up.
hotcob
Thanks for that 69hemibeep . I had a look on moparts.com and all had good reports on it. Maybe they're family.
I'll give it a try on some suspension bits.
bigmanjbmopar - My trunk looks very similar to yours and I've been thinking of using Rust bullet - it sounds easier to use than POR 15 and just as good.
