porblem with door handle Z bar and Lock Mech.
Just to say don't know why this happened. Put the Z bar on the door handle to the latch where it is suppose to go. Had to pull down on the latch part to make the connecting ball go into the Z bar. Well the thing was too far down for the lock to work rite. Every time I pushed the door button even though it was locked it would pop the lock. So had to drill it out to a new location. This became an long gated slot so had to grind off the excess and sides so the keeper clip would fit now the hole was still open so had a tip from my sandblaster it is ceramic ground it down to fit the hole then welded up the end. Ground every thing smooth and put it back in. Now it work's fine. I even had one off a donor door and it was the same way. Now door lock's and stay's locked when pushing the door button in. Guess will never know why I had to do this but now it is done.
Yes 1968 man pulling tricks out of my bag but it is starting to run low. All of us are doing what we can to get these car's up and running. I see so much on this site of my other roadrunner brother's doing their best to bring these car's back to life. One Runner owner helping another to solve problem's or just give some friendly advice. Or to just talk Runner. :beep:
