moparstuart
Lawrence, Kansas, December 12,
A Kansas farm wife called the local phone company to report her telephone
failed to ring when her friends called - and that on the few occasions, when
it did ring, her dog always moaned right before the phone rang.
The telephone repairman proceeded to the scene, curious to see this psychic
dog or senile lady. He climbed a telephone pole, hooked in his test set, and
dialed the subscriber's house.
The phone didn't ring right away, but then the dog moaned and the telephone
began to ring.
Climbing down from the pole, the telephone repairman found:
1 . The dog was tied to the telephone system's ground wire with a steel
chain and collar.
2. The wire connection to the ground rod was loose.
3. The dog was receiving 90 volts of signaling current when the number was
called.
4.. After a couple of jolts, the dog would start moaning and then urinate.
5. The wet ground would complete the circuit, thus causing the phone to
ring.
Which demonstrates that some problems CAN be fixed by
pissing and moaning.
Thought you'd like to know.
began to ring.
chain and collar.
called.
ring.
