Painless Wiring Harness problems
Just since it was rewired? What year? Starts but when you let the key go to run it dies? Oh and hello!
Welcome. Check your ignition switch wiring. The circuit for run is not powered when the key comes off crank.
Do you have power to the ballast resistor with key in on position. Is the bulkhead connector still being used on the fire wall.
