I drove the car locally to find a place to rebuild the engine and putting the car in reverse was near impossible. Gears 1-4 were easy but reverse, was terrible.
Since the trans was out, I took it to a standard trans shop and they will fix the reverse for $150 plus parts. I was there when he took the reverse linkage off and tried turning the cam by hand with a wrench and it was still near impossible. So I'll get the trans fixed while I'm waiting for the machine shop to tear down and rebuild the engine. Cam is not here yet, so tomorrow when the cam comes in, we'll take the engine to the machine shop.
Since I had the radiator out, I took it to the radiator shop to take off the tank check the tubes and fix any leaks. Good thing I did. The lines/tubes in the radiator was partially clogged and there were several small leaks. Now its all fixed and being painted. All this was suppose to be done. When I seen the water that came out of the radiator, I knew I had to have the interior of the radiator inspected.
This is not a good journey :huh: and I guess I'll start :cheers: because it seems like I'm beating. :brickwall: But I'm sure it will be worth it at the end. :banana:![RoadRunner :beep: :beep:](/mopar/styles/default/xenforo/smilies/beep.gif)
I know,
![Blah :blah: :blah:](/mopar/styles/smilies/blah.gif)
I know,
