no dash lights
generaljmwlee
NEPA
just getting dash all hooked up and I cant get the dash lights ,or wipers working. I tried using the wire diagrams traced wires and have power. is there anything I should check other than ground before I start ripping it fully apart?
As you probably know the orange wire work all the dash lights and if that's hot and your grounds are good you might have a crack in the circuit board. The wipers I would guess is at the switch or bulk head connector.
Dash lights might be a dirty or bad rheostat on the dimmer switch. Try turning the switch up and down a few times before you do anything else. Check voltage going to the switch next.
http://www.cabelas.com/product/Hunting/Lights/Headlamps%7C/pc/104791680/c/104743080/sc/104379480/Primos174-Top-Gun-Headlamp/715312.uts?destination=%2Fcatalog%2Fbrowse%2Fhunting-lights-headlamps%2F_%2FN-1100172%2FNe-1100001%3FWT.z_mc_id1%3D43000000037403562%26pcrid%3D%26WT.srch%3D1%26WT.tsrc%3DPPC%26WT.mc_id%3Dgoogle%7Ccam_Lights_Headlamps%7CUSA%26rid%3D20&WTz_l=PPC%3Bcat104379480 Sorry I couldn't stop myself :jester: I need to go grab my wiring diagram
:lmao: :basketcase:
better grab two of those so the gf/wlfe can have one too.... :lmao: wouldn't wanna get stopped for just havlng one headllght.
generaljmwlee
NEPA
ok update- tore our inst cluster think i found the problem with the dash lights, (I hope)the top peg (inst light feed) was broken off. for some reason I dont think i have a good ground was testing for power with a test light at the light socket and one side was bright other was dim (with no bulb in )or its back feeding from something else? :brickwall: did i ever tell you guys I HATE ELECTRICAL PROBLEMS!!!!!!!!!
