new problem
generaljmwlee
NEPA
:brickwall: :brickwall: got to the show no problems. on the way home it started bucking on acceleration , then a pop out the carb then it took off like a rocket . according to the eddy cd that came with the carb it could be a lean condition. what do you guys think? it is a 1406 eddy carb do you think I should tear it down look for dirt or get a holley? I did remove the carb and turned it slightly on the side to clean the gasket off when I put the spacer between the carb and intake.
generaljmwlee
NEPA
next question will the stock air cleaner fit with a holley and what one do I get for a basic stock rebuild?
Start looking for vacuum leaks, especially around the base of the carb.
If you didn't have this problem before adding the spacer, I would agree with Big John on the vacuum leak.
abodybill
Senior Citizen Member
MI. Farm
Agree with Big John about the vacuum leak.
Don't like eddys but,put it back on with the spacer and get acan of carb cleaner and start the engine up and running.
Then start spraying the carb cleaner from the spacer at the intake and up till ya find the vacuum leak.
generaljmwlee
NEPA
sprayed all around no vac leaks . its got to be loading up! trust me lost the hair on my arm with the fireball that pop out with the when I stabbed the throttle. next step I guess is take off the top and check for dirt and clean it. any other suggestions before I start surgery?
check and see if one of the metering rods is stuck down, there under the two small caps on top.
jays69bird
Oswego
I went through this when I replaced my AVS,turned out it was timing not the carb,my balancer's mark could not be trusted,it was showing timing was ok. It only takes a minute to check before you start pulling the carb apart.
I searched my old thread its called 383 timing issues with me as the author its from 09 but it deals with the fireball through the carb and such.Its got a lot of good troubleshooting tips from the guys on here.
4spd69RR
Winter Springs, FL.
Did the engine do this when it was cold. You might have a vacum leak around the intake. My old runner had a similar issue when I would first crank it over. After allowing it to warm up it ran fine. I had to use a can of ether to find the location of the leak.
abodybill
MI. Farm
Eddy carbs are known for very very bad quality control such as dirt and shavings inside of the carb.
Just a thought and my :cents:
When its backfires through the carb, that indicates a lean condition or timing issue. I take a propane torch and open the valve a little and stick it in the throat of the carb and see if it picks up rpm. If you dont have a torch then just close the choke a little and see if it improves. Also the accelerator pump could be the problem. Check for proper pump shot. I friggin loathe Edelbrocks carbs. Its amazing to me how they took Carters reliable and excellent performing carb and make it a complete pile o poo. Get a Holley 750 double pumper and dont look back Holley list number 4779. Four corner idle as well.
generaljmwlee
NEPA
took the top off the carb and found dirt took it all apart and cleaned everything. after it was back together took it for a ride . started pulling out and hammered it and holy sh@$ broke the tires loose and went side ways !no more popping! :party: :party: :party: :cheers: Thanks for all the advice!
:cheers:
abodybill
MI. Farm
Like I said in my post on the Eddy carbs they come with Free Dirt and Shavings from the factory and at NO charge. :D
No QC or very little!
Past experince with them.
That's whay I switched from eddys to holleys.
Glad that you got it fixed :yesnod: :thumbsup:
