New Dash Installed
Very nice. If you don't mind me asking, what all did you have them do to the dash? and what was the cost?
Bob - I think we just found a companion to your car. Both road runners would give each other a run for their money on any concours field IMO.
I'm having flashbacks watching these posts the detail is great, keep it up :thumbsup:
solid gold
Saint Louis, Missouri
Thanks ,Guys , for your comments! I'll tell you, when I got the 1st estimate on the dash it was a shocker, let alone the final one. It's like an ala carte menu (the estimate). When you choose a few items, they'll look great, but then the rest will look like sh**. So I just ordered everything on the menu. Gotta' love those 0% c.c. for 12 months. I'm trying to figure out how to post that menu. :loco: I must be crazy! " You do look @ the dash every-time you drive!" (at least, that's what he told me !) :drive:
so true :thumbsup:
Yup - back when I owned my car the first time (long story short: bought it in 83, sold it in 88, got it back in 2000) I was having it painted and wanted to put the stripes on the hood but wasn't sure I could afford it. A good friend told me "if that is what you want you'll kick yourself later for not doing it now." I thought about that and had the stripes put on. I was so happy I listened to him!
solid gold
Some of you wanted to know what was all done to the dash, so here's what was done to it.
Disassembly/assembly--sandblast, prime & paint dash frame--re-dye upper pad--replace glove box pad--re-dye lower dash pad & glove door--restore switch panel--clean,test & detail switches (5), rebuild dimmer--restore & re-plate ashtray assembly 100%--supply new glove box liner-- repair & restore 4spd indicator--replace lighter element (NOS)--supply Road Runner decal--restore heater control assembly 100%-- restore map light assembly 100%-- re-dye radio bezel-- convert radio to AM/FM stereo (180 watt), (mp3, ipod, cd, xm/sirius radio ready)--replace front speaker--instrument bezel: strip chrome, detail paint-- replace damaged vent cable--replace defroster vents & supply hose kit-- supply new wiring harness-- ignition switch (NOS)-- ignition lock cylinder (NOS)-- ignition switch bezel nut (NOS)
Cluster: restore case-- paint pointers-- re-face alternator, fuel & temp-- reface speedo-- rebuild & calibrate speedo-- re-screen odometer wheels-- solid state voltage limiter-- supply good original tach core-- rebuild & upgrade tach to electronic-- re-face tach dial-- paint & supplies. That about covers it ALL! :crazy:
