Lower Ball Joints
TOMRR
Mass
What's the easy way to install the lower ball joints into the lower control arm I just got the lower arms back from firm feel and they were powder coated, I took my drummal and clean the powder coating out of the hole, is a matter of a big hammer or do they need to be pressed in ??
Thanks Tom C.
Put in the hole and tighten the nut. Don't forget a new cotter pin.
That's all you need to do.
Put your grease zerk in so it gets pointed in a direction that is serviceable before tightening if its a 90 degree type
TOMRR
Mass
I f----- up I thought they went threw the top !!! Thanks for the Reply's All Set
