Flat tappet vs roller cam
1969Claw
Calgary, Alberta
I have a 69 roadrunner 4 spd. w/ a 500+hp 440cid / trick flow heads (with spring and valves etc.). I have started to hear a little lift noise and was thinking of just replacing the Comp 21-224-4 cam with one of the Comp XE roller cam vs just a complete lifter change. The car is 98% street driven. Thoughts/suggestions.......
Roadtrip
Alberta
A roller cam would just ultimate piece of mind that you won’t flat the cam, but the lifters can still fail. A friends FE390 had bad comp roller lifters around the pin and roller area. Do you already have adjustable rockers?
1969Claw
Calgary, Alberta
Yes, I have adj rockers. Looking for a slight increase in performance with a roller, just not sure which one. Not quite sure how to compare the two cam types.
WWheeler
Dallas
A local Hi Po engine rebuilder recommended a roller cam over the flat tappet cam. Reason being metallurgy and not because of performance. A roller cam will always be billet and has more reliable metallurgy than the cast flat tappet cams. Problem is where these are made. Just can't trust what you are getting these days. You might find a great flat tappet cam or not. At least with a roller cam, you start with a better construction.
