chapdog105
I keep going back and forth on my engine build preference.
I don't have the 383 that was original to my car, and I'm okay with that.
I do have a 440 block dated from 69 that has been balanced, and is waiting to be built.
I haven't purchased the cam, carb, gaskets, etc. because I haven't been able to make that large of a purchase while having the body and paint done, and I also haven't committed to a combo.
I have been tossing around going with efi lately. What is that take on this? Looks like it will cost about as much as building out a 4-barrel with a repop Air Grabber set-up, or going with a 6-barrel set-up, both of which I've considered.
My goals for the car are to have a clean classic Mopar, without going over the top with correctness, as it will drive me crazy trying to make it 100% correct. I'm doing my best to make the car as correct as possible in most areas, but if a bolt is incorrect, or the paint color isn't correct, I'm okay with it. The body and paint is amazing, and most parts and pieces will be brand new or restored.
Having a car that I can drive as often as I want all summer long, that will get up and move is the plan.
Having about 400-450 hp wouldn't hurt either.
What do you fellas think? Is EFI a good option? Or will it destroy the "classic" look and feel of my rare Mopar? Could I run my 906 heads I had reconditioned and the valves hardened? Or should I go with aluminum heads?
I found a MSD kit, EZ EFI kit, as well as an Edelbrock system.
