engine bay wiring
Hurstguy01
Michigan
Good morning everyone, I'm new to the B body Mopar community I have a 70 Belvedere I am working, i will be investing in a rallye dash with the tic toc tach and was wondering if i need to change the engine wiring harness as well? does anyone know what i will need to do to make this dash work 100%. thanks in advance for all of your help.
Welcome. I believe all you need is tach wire under the hood, it has its own hole that would need to be drilled in the firewall. Dash wiring of coarse.
69hemibeep, thanks for your help, the dash has a complete wiring harness with it. Will I need a special harness for the coil to the tach lead?
