Electronic ignition-coil location
CWR
I was talking to some mopar guys at a car show today...........thet looked at my MSD ignition coil and said " That should be mounted vertically instead of horizontally " It seems that mounted horizontally the oil inside doesn't cool as effectively. Any thoughts? I can't find any mention of that on the MSD site. Should I panic?
I think the vertical mounting is in case the coil leaks some oil out. If that happens then you would have a cooling problem. That said, I've only ever seen one coil leak.
Hoosier Bird
Hope, Indiana
MSD Blaster 2 Ignition Coils Ignition Coil - Blaster 2 - Canister - Round - Oil Filled - Red - 45 - 000 V Brand: MSDMfr Part #: 8202
A ballast resistor is not necessary if an MSD ignition control is being used because the ignition is responsible for delivering the voltage to the coil. Do not mount this coil horizontally or upside down. The oil will not sufficiently cover the windings for cooling purposes and the coil may overheat.
Found this on-line........ :cheers:
CWR
so the guys I talked to are on track............I'll have to look at some of the part numbers on my system and look at that site again ..............and I do have a ballast resistor
Well... for what its worth, I've run MSD igintions on three cars, two of which had the coil mounted horizontally with no problems. The other was a Jeep Grand Wagoneer that the original position was upright.
Thread Hi-Jack Alert!!!
Mac, what in the heck do you have for an avatar now...???
Your girlfriend with the blue tube top is my personal all-time favorite... :D
Now back to your regularly scheduled programming...
mac
What ?
lancaster, new york
i'll bring her back eventually but i want to go through some of my other favorites for now. :crazy:
I miis her too! and I'd like to see a shot from the rear. I saw a blonde today with cut offs that was ALL over the place.......... :D
moparmoose3
sorry for interrupting the sweet dreams, but i just got done working on my runner and boy was it a trip. turns out it was the coil. first thought was the battery, then we went to checking the coil for spark. didn't have the best spark, but we took an old plug and checked it against a bolt while turning the car over and weak yellow spark. took the coil off and it was leaking all over the place. it was mounted horizontially in front of the carb. that's the second one that went that way. i'm now looking for a place to mount it on the fenderwell. just thought i'd put my :cents: in on this. :drive:
Hoosier Bird
Hope, Indiana
Or just buy the epoxy filled unit (msd 8222) and mount it anywhere you want.......... :thumbsup:
CWR
with the epoxy unit . Is it just a straight swap?
