Edelbrock Performer RPM Heads
JJRJR
Hey guys, I'm posting below the specs from the Edelbrock heads that I was thinking of using in my 383 rebuild. Not knowing what the numbers mean vs the stock heads makes me clueless as to whether this is worth the $1,400 investment or just having my stock heads machined?
Can you guys look at these numbers and let me know why the Edelbrock Performers are better (aspiration, horsepower, torque, etc.) I don't know what the numbers are of the stock heads and I think if it's explained to me that way, I'll get it.
Thanks, John.
Combustion chamber volume 84cc & 88cc
Intake runner volume 210cc
Exhaust runner volume 70cc
Intake valve diameter 2.140"
Exhaust valve diameter 1.81"
Valve stem diameter 11/32"
Valve guides Manganese bronze
Deck thickness 5/8"
Valve spring diameter 1.55"
Valve spring maximum lift .600"
Rocker stud N/A
Guideplate N/A
Pushrod diameter 3/8"
Valve angle 15°
Exhaust port location Stock
Spark plug fitment 14mm x 3/4 reach, gasket seat
Made In USA
SomeCarGuy
Sometown in KY
The chambers are much better than stock. I haven't seen a stock 906 flow sheet in years, but I think OOTB the heads flow a little better all over the chart. More potential when ported than the stock heads, won't be a risk of cracking. Less weight on the front of the car.
Have you priced a refreshening of your heads yet?
JJRJR
No I haven't yet spoken to a shop about working the stock heads. I do like the aluminum Edelbrocks and I'm thinking it would cost at least $500 maybe more to machine stock heads, plus new springs, valves, etc. Seems the Edelbrocks for $1,400 a pair maybe the way to go. Just wanted to be sure that OOTB they are much better than stock. Don't want to spend $1,400 then have to get those machined.
Thanks,
John
Edelbrocks do require at least a check as the valve job they do is terrible and you will be redoing them if you take them out of the box and throw them on. I figure it will cost $1000 more to go with Edelbrock over a nicely rebuilt stock head.
generaljmwlee
NEPA
i have 2 friends who just put them on an never had any problem ! grant it ones a gm and the other a sb mopar but they love them!
