SgtLee511
I worked hard, and got my front suspension back in my car. I had built my drum brakes on the bench, then I installed them with the backing plates onto the suspension. First thing I notice was, brake lines from wheel cylinder were to the front of backing plate. They should be to the rear of the plate. So to correct this a simple swapping of sides put them in correct positions left and right side. So now Im sitting back looking at this, thinking Its done. Then I realize the auto adjusters which happen to be labeled L or R must now be on the wrong sides. I figure I have to correct this, because I'm thinking the adjusters will not operate correctly. The left is at the front of the drum. So will it work? That way....... ?
