computer tech support
moparstuart
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0. I soon noticed
that the new program began unexpected child processing that took up a
lot of space and valuable resources.
In addition, Wife 1.0 installed itself into all other programs and now
monitors all other system activity. Applications such as Poker Night
10.3, Football 5.0, Hunting and Fishing 7.5, and Golfing 3.6.
I can't seem to keep Wife 1.0 in the background while attempting to run
my favorite applications. I'm thinking about going back to Girlfriend
7.0, but the uninstall doesn't work on Wife 1.0 Please help!
Thanks,
Troubled User.....
_____________________________________
REPLY:
Dear Troubled User:
This is a very common problem that men complain about.
Many people upgrade from Girlfriend 7.0 to Wife 1.0, thinking that it is
just a Utilities and Entertainment program. Wife 1.0 is an OPERATING
SYSTEM and is designed by its Cre ator to run EVERYTHING!!! It is also
impossible to delete Wife 1.0 and to return to Girlfriend 7.0, It is
impossible to uninstall, or purge the program files from the system once
installed.
You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not
allow this. Look in your Wife 1.0 manual under Warnings-Alimony/Child
Support . I recommend that you keep Wife 1.0 and work on improving the
situation. I suggest installing the background application "Yes Dear" to
alleviate software augmentation.
The best course of action is to enter the command C:\APOLOGIZE! because
ultimately you will have to give the APOLOGIZE command before the system
will return to normal anyway.
Wife 1.0 is a great program, but it tends to be very high maintenance
Wife 1.0 comes with several support programs, such as Clean and Sweep
3.0 , Cook It 1.5 and Do Bills 4.2!
However, be very careful how you use these programs. Improper use will
cause the sys tem to launch the program Nag Nag 9.5 Once this happens,
the only way to improve the performance of Wife 1.0 is to purchase
additional software. I recommend Flowers 2.1 and Diamonds 5.0!
WARNING!!! DO NOT, under any circumstances, install Secretary With Short
Skirt 3.3 This application is not supported by Wife 1.0 and will cause
irreversible damage to the operating system!
Best of luck,
Tech Support
