72 RR in car 340 rear main seal help
Not sure if it is a two part seal or held by oil pan still have to drop trans. to get to her. Other motors worked on could work it out with a tool then put the new one in. Hope some of the other guys will give you more solid advice. Search of the part's manual on this site may provide the answer you are looking for. Russ. :wave:
Well did not see any one else giving advice. Like I said have used a screwdriver pried it out then put the new one in on most motor's. Wish you well on the job. Russ.:yesnod:
