Something to help decode your VIN and FENDER TAG tag - 1968 ONLY
Here's something I put together to assist in decoding 1968 ONLY - VIN info and FENDER TAG information.
Is it 100% correct? Nothing is 100% especially when it comes to Mopars. I've done my best to make it as accurate as I can.
The PDF file is 4 pages.
Frank
  • Fender Tag and Vin Decode.pdf
nevada dan
I was just checking out your decode and my tag has the H under the s on row 3 and it says accent stripes , what do these look like , my car had been painted several times and they are long gone , might want to put them back on
As I understand it (and I'm no expert) but I THINK the "H" under the s may be RED Horizontal stripe, which MAY be the fine pin stripe that goes along the length of the car.
Does that make any sense to you. What color was your car originally.
In this case, for me, it's a WAG
nevada dan
the T1 green that it is now, had a white top and green interior but I changed that to black, I thought red pin stripe also but cant quite picture that with the green, they are a vinyl decal aren't they, I just might have to get them and try it on
Well, back in '68 some people made many bad color choices (and didn't know it).
But you never know, the red on green may work (think Christmas).
In 69 the pin stripe came in white and black also if memory serves. The dual reflective tape was a different code, to short of time to look it up right now.
RKNRLR
Sydney, Australia
Frank
Good Work, real easy to read.
MsBeep
Alberta, Canada
Frank
I had lost some good links when I changed devices in 2021. Much appreciate the pdf. file
