Pulling my A833 trans.
Can I pull the trans. if taking the shifter loose and disconnect the shift linkage loose. Hope I can sneak the trans. out. Need to do a seal replacement on the front shaft. I have a console and really don't want to pull it if I don't have too. Thanks for any input. Russ.
HD539
Pacific Northwest
It seems like you should be able to. With that said however I pulled my console last time I had my transmission out.
You would have to disconnect the exhaust to tip the engine far enough to clear the the cross member. Take the shifter off.
