Anybody have a jegs distributor 555-40504?
Russ Hood
TN
Chased my problem to this. I called jegs and they dont have a pickup that goes into the distributor and hooks to the harness. This was on the car when I got it.
Got my distributor from Summit racing. Cheap enough to just replace it. Think the hole kit was around 134 bucks.
They included a harness that would wire into your system. If I remember right got the orange box and the blast resistor with the kit. Knock on wood it is working well.
Russ Hood
TN
I put the m&h harness in with the orange box I had ordered that did have the wiring harness but i didnt use the one with the wiring harness i used the m&h. The resistor is the double sided one not the single.
The distributor I bought came with the wiring and instructions on how to wire it in. It was pretty simple. I used the under-hood wiring harness from year one also. It all worked out well. Hope you solve your problem and get that car on the road. Have a good one. :thumbsup2:
